4 members (TooMany2count, MNSmith, moparguy, TexasJim50), 56 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#42853 05/04/2005 9:27 PM
My '66 250 runs good but it just doesn't want to stop when I turn the ignition off. I'm no mechanic so please tell me what causes an engine to keep trying to run when it's switched off? Is there anything I can do here in the shop until I can take it to my mechanic to get it tuned up properly? It's very annoying and embarrasing.
Mike
#42854 05/04/2005 9:50 PM
is your engine ideling too fast.that will cause it and most times is the easiest to remedy
#42855 05/04/2005 10:06 PM
Many times it is caused by carbon build-up in the cylinders. The carbon becomes hot enough to ignite the unburt fuel that is still in your cylinders after you shut the key off. A too rich fuel mixture can cause this condition.
sowsear46, its good to have another Panhandler on the 'Bolt. Next time I drive through Hale Center, you will have to show me your truck.
Phil
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
#42856 05/04/2005 10:12 PM
Riding in the Passing Lane
46 is right. Toofast idle will cause it. Many of those of that era had an idle selenoid for that reason. Also a vacuum leak can cause it. If it is an auto trans. you can help by turning the ignition off while it is still in drive. smile
1972 Chevy c10 Cheyenne Super
#42857 05/04/2005 10:16 PM
She idles real low and it is a 4 spd w/ granny trans. I did notice black sut on the car port floor where I crank it up all the time. It only runs on after it gets hot from driving. If it is carbon build up then how or what can I use to try and clean it out?
Mike
#42858 05/04/2005 11:19 PM
With engine running at a fast idle pour water slowly down the carb. to clean out carbon. Too hot of spark plugs can cause it also. How about the carb. base gasket. What carb does it have model B or monojet Rochester?
#42859 05/05/2005 10:23 AM
ove Offline
Apprentice
Apprentice
I have used some vacumhose on the carburetor to put water in the engines I have tried this on. This gives you a more controlled volum. To mutch water will kill your crankshaft bearings.
#42860 05/05/2005 3:44 PM
I like Seafoam to remove carbon has done the trick for me. Put a 1/2 to full can slowly down a vacuum line or down carb throat on a fully warmed up engine. Put the last little bit in fast to kill engine, let sit 5-10 minutes then go drive it like you stole it. Will white smoke a while, don't be alarmed. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#42861 05/05/2005 5:57 PM
Junior Member
Junior Member
Glad to hear that I am not the only one with a 66 250 that does the run on thing.
MikeP
