4 members (walter74, Stovebolt48, Shardean, 1 invisible), 69 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
I
I Offline
I have determined the fuel pump in my 49 is bad. Well it is a later model engine, I think a 235 but anyway I was told it is the same fuel pump. Are there any tricks to this replacement. I have done several Chevy 350s and such and the only trick to them is a longer bolt to hold the push rod out of the way temporarily. Anything unexpected to the inline six??
My new 1949 Chevy One Ton Dump Truck. Still have it but parked, needs a new motor.
1953 2 ton parts truck Long Gone
1957 GMC LCF On 75 Cadillac Eldorado Frame
Updated Feb 2021
Turn the engine so the pump cam lobe is at the low point. That keeps you from having to compress the pump spring and holding the pump against spring force while you install the bolts. Otherwise no tricks.
Harvester
Ex Hall Monitor
Ex Hall Monitor
What he said. grin
I had to cut a wrench in half to get access. I mention this before and nobody else said that they encountered the problem. Also, if you have the fuel tank in the cab, you must shut it off because as soon as you crack the inlet nut, the tank will start to empty on you.
1951 1 Ton Completed
Especially what Truckernix said.
dj durant
More pix on Flickr
