1 members (baldeagle),
52
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 10 New Guy | | New Guy Joined: Jul 2007 Posts: 10 | Hi all, I followed the Tech instructions regarding the 12 volt conversion. But, I used an alternator from a 96 lumina van out of the local junkyard. I connected the red wire from the alt. to the old batt. wire from the old regulator. Now, there are two wires left on the alt. One is pink. I wired it to the + side of the coil. The remaining wire on the alt. is brown. I just rolled it up, not used. Truck starts great, have head lights, tail lights, horn (real loud now, interior lights,etc. But, when i try the turn signals or the flasher, the tail lights go out. front signals have only one on constant and the volt gauge just stays stuck in the middle. No signals working at all. Now, what did I do wrong? And, what about that lef over brown wire on the alt.??? I tried a volt meter on the battery while truck is running and it seem to be charging. Can you help??? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Wayne - the alt shouldn't affect the signals, you've got some other wiring messed up, or there's bad grounds somewhere - you need to check/track all the signal/tail light wires and make sure they're correct - can't say exactly how it should be, but sounds like you've got the alt hooked up right - someone here will link a wiring diagram for the conversion
Bill | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I don't think this relates to the alt. wiring either. Double check the grounds on all your lights. | | | | | Joined: Jan 2008 Posts: 4,959 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,959 | Are you using a 12 volt flasher? A steady burning in front usually means no continuity in back. Either burned out bulbs or lost ground in back. Are your flashers separate from the stop lights? Did your flashers work before the conversion? | | | | | Joined: Jul 2007 Posts: 10 New Guy | | New Guy Joined: Jul 2007 Posts: 10 | Hi, yes, I replaced everything with 12 volt items. No, I havent checked for burned out bulbs yet. No, the flasher is part of the tail light. One bulb alone for signaling and stopping. They were newly installed with all the other bulbs. I have another question. Is the old "signal-stat 900" blinker switch that came with the truck, 6 volt??? That may be the problem? What do you think? Classicparts has one that is 6-12 volt able.
Wayne | | | | | Joined: Jul 2007 Posts: 10 New Guy | | New Guy Joined: Jul 2007 Posts: 10 | Hi, yes, I replaced everything with 12 volt items. No, I havent checked for burned out bulbs yet. No, the flasher is part of the tail light. One bulb alone for signaling and stopping. They were newly installed with all the other bulbs. I have another question. Is the old "signal-stat 900" blinker switch that came with the truck, 6 volt??? That may be the problem? What do you think? Classicparts has one that is 6-12 volt able.
Wayne
| | | | | Joined: Mar 2008 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 43 | The turn signal switch will not matter. The only thing with it would be the bulb. The switch just makes a connection and doesn't care if it is 6 or 12.
Spencer | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You need a 12V flasher too.
