| | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#42793 08/16/2002 7:42 PM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Would like to pick up a 500 cfm carb this weekend. The Edelbrock is readily available while a good Carter of the same size is not. Is one as good as the other? I'm looking at the manual choke (I think) because I can't figure out where to get the power for the electric choke :mad: :rolleyes:
I think this is a good pick for a 292 bored .060 over. Should be enough cubic inches to handle that size 4 barrel.
-ftyler | | |
#42794 08/16/2002 11:59 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Also look at the 500 CFM 2bbl Holley. They are easy to setup & tune, cheap, and readily available. Hook the electric choke to 12 volts when key is on.
I like 2bbls because the throttle response is good at low/midrange RPMs compared to a 4bbl. There is no secondary transistion or fuel delivery to worry about.
Good luck
Chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#42795 08/17/2002 3:32 AM | Joined: May 2002 Posts: 20 Member | | Member Joined: May 2002 Posts: 20 | Carburetor websites and Hollys own information says 4bbl carbs and 2 bbl carbs are CFM rated at different vacuum depressions. Looks like a 500 cfm 2bbl is only 350 cfm when rated the same way as a 4bbl.
Porky Pig is just a ham.
#42796 08/17/2002 4:02 AM | Joined: Nov 2001 Posts: 72 Member | | Member Joined: Nov 2001 Posts: 72 | Edelbrock also bought out Carter. No more new Carter's Dennis | | |
#42797 08/17/2002 6:04 PM | Joined: Mar 2002 Posts: 12 Junior Member | | Junior Member Joined: Mar 2002 Posts: 12 | The Edelbrock and the Carter are identical. New carters (made by edelbrock) are available from PAW.
1953 M38A1 (Military Jeep) 1962 K10 1963 FC170 (Ugly Jeep)
#42798 08/21/2002 2:19 AM | Joined: Nov 2001 Posts: 58 Member | | Member Joined: Nov 2001 Posts: 58 | Bolters: At last years Inliners Int'l meeting in PA in August there was beaucoup discussion on the holley vs Edelbrock 4bbl carbs on inline chebby sixes. While there was no universal concensus the Edelbtrock carb came out as being more user friendly to tune for the sixes. Bubba
Bubba
#42799 08/21/2002 7:10 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The question now is Edelbrock vs. Holley. I was set on the Edelbrock, went into my parts store, the convinced me to buy the Holley. Unless you find an older Carter, which is still a good carb. And it does help with the classic/nostalgia theme, too.
Fred 52 3600 69 C-10
