6 members (Phak1, 49fastback, Biermann, Jaison, moparguy, NJC), 109 guests, and 2 robots.
Topics128,137
Posts1,056,747
Members48,454
Does anybody know how to loose and install the inner seal?
'59 Apache
'67 Mustang
Riding in the Passing Lane
The usual way is to put a large drift in from the other side & hammer it out with the bearing. This can damage the bearing though. You can pry it out or cut a groove in with a chisel & pry it out. You must always replace them. They can be put in with a large socket that contacts the outer edge & hammer or if you are real careful you can tap it in from around the outer edge.
1972 Chevy c10 Cheyenne Super
I was told to replace the seal when ever you start to see grease seep pass the seal. When ever I need to remove the inner seal. I remove the outer bearing and washer, put the nut back on and drag the drum (disk) off the spindle. The seal usually ends up coming off with the nut.
Larry
I don't own a vehicle that isn't old enough to drink.
