4 members (Guitplayer, Hotrod Lincoln, Bill Hanlon, Gdads51), 106 guests, and 2 robots.
Topics128,109
Posts1,056,271
Members48,439
#426054 06/23/2008 11:48 PM
I found a complete t5 trans with bell housing and everything in a local pick and pull yesterday and would like to know if the bell housing will work behind a 250ci
1938 Gmc 1/2 ton
Depends. What engine did the S 10 have in it? If it was a 4.3, then you should be ok, but if it was a 2.8, it won't work. I'm not cerain about the 4 cylinder S trucks.
Bill Burmeister
the 2.8 and 4 cyl in any vehicle is a different bell housing than the V8. the 4.3 v6 is basically a 350 with cyl 7 & 8 missing.. it has the same bell housing bolt pattern as a V8.
I dont know what bell housing the 250ci 6 used.. I would ASSUME its the V8 bell pattern.. sorry on that bit.
That is correct, the later 7 bearing 6 cylinder uses the same bellhousing pattern as the Chevrolet V8s.
Bill Burmeister
I didn't even think about looking what size engine was in it, but with the info I got here already I can go look and know what to look for thanks
1938 Gmc 1/2 ton
TheShoer #426827 06/26/2008 11:43 AM
Post a pic if needed, most of us can spot the GM 60 degree pattern vs a 90 degree pattern. If the mounting holes are in line on each side, you have a 60 degree V6 (2.8, 3.1, 3.4) flywheel housing.
The T5 wasnt behind many 4.3's in the S-10. It was behind the 4.3's in the Astro Van.
Scott
i dont recall there being room for a clutch pedal in an astro. I owned one not too long ago and i honestly could not image a manual astro van. I am not a tall person at all and could hardly bare the lack of legroom with the wheel well on one side and the doghouse on the other.
I owned two of them. about 2% of astro sales were manual in 1985-1988. Not available after 1989 that I can tell.
