| | | Forums66 Topics128,163 Posts1,056,920 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 61 | Does anybody know how to loose and install the inner seal?
'59 Apache '67 Mustang
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The usual way is to put a large drift in from the other side & hammer it out with the bearing. This can damage the bearing though. You can pry it out or cut a groove in with a chisel & pry it out. You must always replace them. They can be put in with a large socket that contacts the outer edge & hammer or if you are real careful you can tap it in from around the outer edge. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | I was told to replace the seal when ever you start to see grease seep pass the seal. When ever I need to remove the inner seal. I remove the outer bearing and washer, put the nut back on and drag the drum (disk) off the spindle. The seal usually ends up coming off with the nut.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
