| | | Forums66 Topics128,281 Posts1,058,472 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#42751 06/26/2002 3:57 AM | Joined: Nov 2001 Posts: 58 Member | | Member Joined: Nov 2001 Posts: 58 | If I had the original radiator re-cored do you think it would keep a 327 or 350 cool enough? The engine will end up in the 250-300 HP range. | | |
#42752 06/26/2002 4:52 AM | Joined: Feb 2001 Posts: 40 Member | | Member Joined: Feb 2001 Posts: 40 | I ran a stock '41 radiator in my '38 for several years and only had trouble with overheating when I would run 80+ mph in 80+temps for several miles . If I got onto a slower highway it would cool down . I ran a small flex fan because the motor sat low/lower radiator hose outlet. And no pressure on the system . no shroud on the fan . I now have a new afco aluminum rad. and electric fan , moroso aluminum water pump . hope to try this combo yet this year. I would go ahead and try the recored radiator- might save you a bunch of bucks ! | | |
#42753 06/26/2002 5:06 AM | Joined: Nov 2001 Posts: 58 Member | | Member Joined: Nov 2001 Posts: 58 | Thanks, it looks like it would be big enough volume wise etc. and I was thinking of running the electric fans as well. I may still look a new one depends on what the re-core costs. | | |
