Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (TUTS 59, 68ironhead, tclederman, 2-Ton, wilbur53, 3B), 138 guests, and 5 robots.
Topics128,281
Posts1,058,476
Members48,490
#42751 06/26/2002 3:57 AM
If I had the original radiator re-cored do you think it would keep a 327 or 350 cool enough? The engine will end up in the 250-300 HP range.
John....38 Chevrolet Panel Delivery
http://community.webshots.com/user/tobytailford
#42752 06/26/2002 4:52 AM
I ran a stock '41 radiator in my '38 for several years and only had trouble with overheating when I would run 80+ mph in 80+temps for several miles . If I got onto a slower highway it would cool down . I ran a small flex fan because the motor sat low/lower radiator hose outlet. And no pressure on the system . no shroud on the fan . I now have a new afco aluminum rad. and electric fan , moroso aluminum water pump . hope to try this combo yet this year. I would go ahead and try the recored radiator- might save you a bunch of bucks !
#42753 06/26/2002 5:06 AM
Thanks, it looks like it would be big enough volume wise etc. and I was thinking of running the electric fans as well. I may still look a new one depends on what the re-core costs.
