Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Shade Baby), 21 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#42704 12/19/2003 6:20 AM
I have an engine my dad had rebuilt years ago by a super mechanic - very precise, very picky. Dad's been gone a couple years so can't help me. He always said it was an early 54 235, of the low pressure type. Is this possible? Would this have inserts or babbits? How can I tell? Any other insight would be greatly appreciated!
#42705 12/19/2003 9:19 AM
Get the number off the outside of the block .
It may be behind the starter , or below the dist.
Raised numbers cast in the block.
#42706 12/19/2003 1:36 PM
If it is a 54 block, there should be a stamping on the flat area just to the rear of the distributor with F54 in the sequence. there are casting numbers for engine ID on the www.inliners.org site
#42707 12/19/2003 8:47 PM
Okay, now we're getting somewhere. It's a 3835911 casting, and the f54 you referenced is there. What more can be determined, and what is inside this baby? Dad's info seems accurate in that it is an early 54 model. Babbits or inserts, worth using or not?
Thanks guys!!!!
#42708 12/20/2003 1:36 AM
Should be insert bearings. Mine still runs rom a rebuild 10...11 years ago smile
#42709 12/20/2003 2:07 AM
3835911 is '54 first series 235.
Should be a good engine .
#42710 12/20/2003 4:31 AM
Thanks! I had planned on using it someday either way I guess. Dad had a verrrry fussy and precise craftsman rebiuld it decades ago, only to sit unused. His investment will someday be the pride of my truck for what I hope is a long time.
Happy Holidays!!
