4 members (HandyAndy, '37 barn find, cmayna, ESum), 117 guests, and 6 robots.
Topics128,210
Posts1,057,465
Members48,471
I have a 48 Chevy 1/2 ton. The gas tank is under the bed. The filler neck comes out of the box side. I want it to come up through the bed floor. Any suggestions on how to do this? I dont have a welder though....
You can cut the neck off before it reaches the side and reroute it using a rubber hose and clamps. You should deal with the vent somehow.
~Jim
i like mine this way
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=0465700-R1-035-16.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=DSC00372.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=DSC00310.jpg
but maybe you can't/ don't want this............
a friend went on a long trip to a rally w/ his AD. the bed was loaded w/ camping equip. etc. when he
went to put gas in the truck at his first stop he unloaded/re-loaded 1/4 of the bed just gas-up. frown ,
food for thought headscratch
Jim & Caroline
Thanks for the info. Carolines truck, where did you get the filler neck? Right now I have the pipe that ends right inside of the bed side. i need a filler neck to stick through the bed side.
my filler neck also comes out of the bed but just below the wood, still in the bed exterior wall w/ a somewhat D or oval hole cut there. the filler neck you see in the photo is the very same one i took off the cab passenger side of my 51. i made a plate (very carefully) and drilled three holes (one hole is above the wood) to mount it to the bed outside wall. i cut off & welded the overflow hose up as well as welded the now 180 degree inverted filler to the plate i made. i added a 2'' piece to connect the gas hose to as well as the new tank.
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=DSC00309.jpg
http://s67.photobucket.com/albums/h...&current=3100lockinghoodlatch-02.jpg
http://s67.photobucket.com/albums/h...&current=3100lockinghoodlatch-05.jpg
be sure you ground the tank & sender to a good frame &/or cab ground. grin
Jim & Caroline
I would avoid coming up thru the bed floor if you plan on hauling anything (including camping supplies to a show). I thought an in-trunk fill would be "cool" on a Dodge Demon as the clean look was what I was after. After unloading the trunk every 250 miles for fuel, I rerouted the fill neck to the rear of the car behind the license.
Scott
