| | | Forums66 Topics128,196 Posts1,057,390 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 92 Shop Shark | | Shop Shark Joined: May 2006 Posts: 92 | I have a 48 Chevy 1/2 ton. The gas tank is under the bed. The filler neck comes out of the box side. I want it to come up through the bed floor. Any suggestions on how to do this? I dont have a welder though.... | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | You can cut the neck off before it reaches the side and reroute it using a rubber hose and clamps. You should deal with the vent somehow.
~Jim
| | | | | Joined: May 2006 Posts: 92 Shop Shark | | Shop Shark Joined: May 2006 Posts: 92 | Thanks for the info. Carolines truck, where did you get the filler neck? Right now I have the pipe that ends right inside of the bed side. i need a filler neck to stick through the bed side. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | my filler neck also comes out of the bed but just below the wood, still in the bed exterior wall w/ a somewhat D or oval hole cut there. the filler neck you see in the photo is the very same one i took off the cab passenger side of my 51. i made a plate (very carefully) and drilled three holes (one hole is above the wood) to mount it to the bed outside wall. i cut off & welded the overflow hose up as well as welded the now 180 degree inverted filler to the plate i made. i added a 2'' piece to connect the gas hose to as well as the new tank. http://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=DSC00309.jpghttp://s67.photobucket.com/albums/h...¤t=3100lockinghoodlatch-02.jpghttp://s67.photobucket.com/albums/h...¤t=3100lockinghoodlatch-05.jpg be sure you ground the tank & sender to a good frame &/or cab ground.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I would avoid coming up thru the bed floor if you plan on hauling anything (including camping supplies to a show). I thought an in-trunk fill would be "cool" on a Dodge Demon as the clean look was what I was after. After unloading the trunk every 250 miles for fuel, I rerouted the fill neck to the rear of the car behind the license.
Scott
