2 members (jmoore, Rusty Heaps), 91 guests, and 4 robots.
Topics128,264
Posts1,058,350
Members48,485
#42693 01/20/2003 6:33 PM
Hi guys, Just wanted to post how Christine's new mill was doing. So far the '60 235 motor has 100 miles and is running well. The only problem is the neoprene rear main seems to be leaking. No weird noises, runs smooth going down the road, good throttle respose.
I'm running Castrol 30WT, no filter. The oil pressure @ 800 RPM hot is 20 PSI. Above 1,000 RPM is 35-40 PSI. Sound about right?
Is it normal for a new engine to "puff" a little blue smoke when started?
Thanks for all the help,
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
Pressure sounds right. The blue smoke at startup could be one of two things. First is that the rings aren't seated. Get on a lonely road and accelerate from 20 to 40 as fast as possible then back down to 20. Up and down several times should do it. The other possibility is did you put in umbrella seals on the valves or go with the O-rings. The O-rings will allow some seepage when the engine sits, but usually doesn't show up for quite a while.
Fred
52 3600
69 C-10
