| | | Forums66 Topics128,057 Posts1,055,812 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | My idea is to weld the panels on through small holes to simulate the original spot welds. I read about this a long time ago but a search turns up all kinds of crap and nothing about welding the panels.
My question is what size holes have others used. I put 1/8" holes in but now I'm wondering if they are too small.
If you have done this, what size hole did you use? | | | | | Joined: Jun 2001 Posts: 169 'Bolter | | 'Bolter Joined: Jun 2001 Posts: 169 | My air punch is about 5/16. I have cut spot welds with a 3/8 cutter and have drilled 1/4 holes. Used them all and never had a problem.
I would think that 1/8 is too small. That's the size of Clekos and I rarely ever get a good weld when "filling" those holes.
Paul | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Thanks for the reply. I'm going to bring them up to 1/4".
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | If you drill a 1/8 hole in the "bottom" piece you can use Clekos to hold the thing together. Not sure how well this would work with a MIG welder but it works like a champ with a TIG. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I used 1/8" clecos to hold it together while I welded the 1/4" holes. It worked nicely. Of course I boogered some very visible welds but nothing an angle grinder can't cure. | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | Cletis...I did all my spot welds via a 1/4" hole. Worked good for me too. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If you don't care that the plug welds don't look exactly like a factory spot weld, a bigger hole is going to give you better holding power.
