| | | Forums66 Topics128,110 Posts1,056,242 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#42660 06/21/2004 8:37 PM | Joined: Sep 2003 Posts: 48 Member | | Member Joined: Sep 2003 Posts: 48 | I have also been trying to hang my 55 235 on my nice new engine stand from harbor freight. I discovered this problem of having to remove the clutch after getting the transimission off. The problem is I also discovered that my motor is locked up so I couldn't get all the bolts out of the pressure plate because of the bell housing. I now have the motor mostly disassembled but I need to know how to get the harmonic balencer off? Is it just pressed on there, needing only a puller to get it off? Or does the center where the hand crank goes turn out before you can pull it off. If it is just pressed on there how do you put it back on? Thanks! | | |
#42661 06/21/2004 9:32 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yes, it is pressed on. It has to be hammered or pressed back on.
#42662 06/21/2004 9:36 PM | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | I used a 3 claw pulley puller my father in law had. Similar to this.. [img] http://www.ttzd.com/tech/timingbelt/pulley21.jpg[/img] I put mine back on with a piece of wood and a big hammer. MONGO | | |
#42663 06/22/2004 1:38 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Don't use a puller like that because you can rip it in half. Use the proper puller that threads into the holes in the center. There is rubber between the outer part and the inner part. To put it back on, use a heavy piece of pipe that fits on the center and hammer the crap out of it. | | |
#42664 06/22/2004 4:46 AM | Joined: Sep 2003 Posts: 48 Member | | Member Joined: Sep 2003 Posts: 48 | | | |
