4 members (Gdads51, DadsFirstPickup, 3B, Joe H), 79 guests, and 2 robots.
Topics128,118
Posts1,056,305
Members48,439
#425989 06/23/2008 6:43 PM
Hey, What happens if you run 12 volt bulbs (little ones, not headlights) in a 6 volt system????? ohwell Are they just dimmer or does it hurt something?
Bruce
My Trucks
Stuff I Collect
Y
Y Offline
I believe they should just be dimmer. shouldn't hurt anything.
Bill S.
Tempe, AZ
jdl Offline
Yeah, they are dimmer, VERY DIM!!! Dimmer than they are now, it's like using a flashlight with 90% dead batteries.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
jdl #426085 06/24/2008 1:27 AM
Ex Hall Monitor
Ex Hall Monitor
As far as I know the only issue is dim....REAL dim.
Tiny #426105 06/24/2008 1:54 AM
jdl Offline
Oh, your bulbs will last twice as long though.
Jordan D. Long
Photobucket
Tiny #426458 06/25/2008 2:40 AM
Thanks, I guess I could use them as I've been called a dim bulb before! grin
Bruce
My Trucks
Stuff I Collect
Ex Hall Monitor
Ex Hall Monitor
Most of the FLAPS around here stock a good supply of 6v bulbs. Why not just put the correct bulb in?
Tiny #426583 06/25/2008 3:59 PM
Depends where your "dim Bulbs" are situated and how they are wired up!
If they are in parallel to another system, they may effect how that system performs downstream from the bulbs.
They can in effect act as a resistor to the power continuing on to the next circuit.
You could throw some 12 volt bulbs into your dashlights, and then find that all the other gauges (oil, temp etc.) read incorrectly whenever the light swich is turned on!
Follow TINY's advice and fit the right part from the start.
"It's not a wreck......It's a natural resource!"
Quote-Doc Bob circa 2006
DOCS CLASSIC GARAGE
Specializing in Hot Rods,
Customs & Street Machines.
My pictures at..........
1936 Chev 1/2-Ton Holden Body
confused? http://www.koalanet.com.au/australian-slang.html
doc bob #426659 06/25/2008 8:35 PM
Doc Bob, would you mind telling us all how 12V dash lights are going to have any effect on a capillary tube temp gauge or a direct pressure oil pressure gauge? Then tell us how it would effect electric gauges on the off chance that he is running 6V electric gauges.
Cletis #426695 06/25/2008 11:19 PM
jdl Offline
Cletis, I was thinking the same thing and that's probably what he meant.
Jordan D. Long
Photobucket
Tiny #426741 06/26/2008 2:51 AM
I'm going to change them. We have a great electrical store here in town. I was making a vain attempt at humor. blush
Bruce
My Trucks
Stuff I Collect
Hi Cletis,
Just to clarify your questions.
I was'nt referring to capillary gauges when I posted the reply.
I WAS trying to convey how a vehicles' wiring circuit is designed to operate as a unit that can be effected by non-standard parts being introduced into the system.
Sure a 12 volt headlight globe won't do anything bar give you candlelight to drive by........but place a 12 volt bulb in the instrument circuit, 12 volt coil in the ignition circuit or even a 12 volt ciggie lighter in a 6 volt system and you ARE going to develop problems!
I was only highlighting the fact to keep 6 volt 6 volt, and use 12 volt parts in a 12 volt system.........
The potential difference to earth through a 12 volt part fitted to a 6 volt system WILL effect any function of a 6 volt part in the loop of the vehicles' wiring.
it's not rocket science!
DOCS CLASSIC GARAGE
doc bob #427180 06/27/2008 3:07 PM
Bruce.............
get rid of all the elecrical systems and just rely on the right foot and the sound from the muffler for cryin out loud.
Save us all from this post !!!!!!!!!!!!!!
( another vain attempt at humour! )
DOCS CLASSIC GARAGE
