| | | Forums66 Topics128,165 Posts1,057,087 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | In the manual it says the frt. drums on a 52 chevy 2ton are demountable. I took off the 6 nuts holding the drum to the hub, gave it a good doush with Pb Blaster, got a bfh and can't get those drums to budge even a little. I was wondering if anyone has demounted drums like these and what happened when you demounted them. The thing is, I knew they wouldn't fall apart, but I can't even get a air gap between the drum and the hub flange.
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Jan 2007 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 66 | Glasman, Did you adjust your front brake cylinders down? Sometimes the brake shoes have literally grooved into the drum somewhat so if the shoes are still adjusted outward, there's a lip on the drum that won't slide past the shoes. If you go to the back side of the drum, there should be an access hole into the brake cylinder where you can crank the length down to loosen the brake shoes. I had to do this on my truck.
Jon
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There may be some slotted screws holding them on. Why not just pull the whole hub off with the bearings. They need packing any how. You have better access to the brakes that way. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | I guess I should have mentioned that the hub and drum is already off the truck cause there's no way to dismount the drum if its on the truck. Thats because the drum is on the inboard side of the hub flange. Dan
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You may hace to drive out the bolts holding them together. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | Thats the thing I love about manuals sometimes. The manual tells what to do and then makes no mention of how to do it, or tells you the really simple things like to get the wheel off first jack up the vehicle. I suppose there has been someone who has tried to remove the wheel and not jacked it up first Back to the hub and drum assy. Hasn't anyone pulled the the hub and drum off a 1 1/2 or 2ton truck ? After soaking for two days I gave it another try with the same result. I thought and looked at this assy all day, okay, I didn't look at it all day, but my thoughts were on it as to how I could drive or press the studs out and didn't come up with squat. If you guys have seen this assy you know what I mean. Where you need to drive or press the studs is between the two flanges of the hub assy. I was hoping someone had removed a drum and knew what the situation was. I'm thinking that maybe the studs were a press fit, but you'd think the manual would have at least mentioned that if they say the drum is demountable. Dan
| | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | Glasman...I had the same problem about a month ago trying to remove the hubs from the drums on my 2-ton. I tried everything short of using explosives! My intent was to remove the hub so I could clean out the old grease. I decided to leave it together and cleaned it out. What are your intentions? If it's just to make it easier to clean, I would leave it alone. It really wasn't that bad to clean inside and out for me with everything still attached. | | | | | Joined: Feb 2004 Posts: 29,872 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,872 | Unless you're planning to replace the drum for some reason, I can't think of why it would be necessary to remove it. If you need to machine the drum, a good automotive machine shop will have the correct adapters to use the bearing cups for centering on the brake lathe. For any other operation such as degreasing, sandblasting, etc, just protect the bearing cups and blast away, or drive the bearings out and reinstall or replace them later. Jerry
| | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Ron and Jerry are right, there shouldn't be any reason to remove the drum from the hub. If the drum needs turning, the machine shop will actually prefer having the hub in place to center on the lathe. If the drum is beyond repair (which is highly unlikely) you'll probably end up having to get a used hub/drum assy. anyway, because chances are a salvage yard wouldn't take them apart either.
Keith If it were easy they'd have grade schoolers doing it! | | |
