8 members (lumbersawyer, JW51, 3B, cshades, cmayna, Gdads51, moparguy, 1 invisible),
102
Mod | | | Forums66 Topics128,064 Posts1,055,860 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | Starter spins but does not engage to turn eng. over...had starter checked (good)..now what? Virg | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Virg,
This must be a stomp starter on your old truck, right! The starter can be fine electrically, but the starter drive can be busted mechanically.
If your linkage is tight enough to cause the starter switch to make contact, the mechanicals are probably engaging the starter drive to ring gear. The fly in the ointment would be the little internal clutch in the drive itself. This is most likely gunny-bagged.
A new starter drive would probably cure the problem.
Stuart | | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | If you have a typical GM starter with an overrunning clutch, the clutch is slipping. A no-load test on the starter won't find that condition. The clutch can be replaced, but you should also replace the shifting fork- depending on the starter. If the starter is the Bendix drive type, usually not a GM application, the Bendix spring is broken, or the anchor bolt has come out. I would suggest taking the starter to a rebuilder to have the work done. You will get a better job that includes replacing brushes, bushings and thrust pad, and turning the commutator.
Harvester | | | | | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | I was trying to get it to turn over from under the hood and just pushing on the button on the starter....I got in the cab and pushed on the foot starter and it turned over...I put a new battery in also so now I'm just trying to get it to fire...prob. hasn't been started for a couple of yrs...thanks for the input...Virg | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | THERE IS YOUR PROBLEM!!! The linkage not only pushes the button, it also engages it too! | | | | | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | My finger pushed the button and it just spun...my foot pushed the pedal in the cab and it worked... | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Yeah, just like I said, the linkage from the pedal to the starter engages the drive into the flywheel, but the button completes the circuit and makes it spin, so even if you push the button, the engine won't turn over unless you pulled down on the linkage. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Isn't it great to have this old stuff?  | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | actually JD [and AD], the starter gear is mechanically engaged by the foot push, via an internal yoke in the nose assembly, the electrical connection only causes the starter to spin .... sounds like you need to get on with tearing some of this stuff apart and refurbishing it instead of buzzing around abusing it further .... quit playing with the toy and start building the truck - takes thought and effort, not money Bill | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | 60 year old anti-theft technology.
| | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Geez, Red58, looks like YOU need to read closer. I TOLD HIM TWICE that the electrical connection only spins it and the linkage engages it.(or the yoke or whatever it is) I HAVE taken my starter apart because it stopped working. I'm not yelling on my end over here but trying to get MY point across! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | OK JD, sorry, I was reacting to ADs [removed] post, just pointing out it's a mechanical problem ....  Bill | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Ok, Sorry myself. I was trying to find ADs post, never saw it, just went on with my business. Didn't know why I was included, I felt kinda confused( a little upset) when you said that, but if you were just talking to him, it's fine and dandy!  | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yeah, fine - I was including you so you weren't mislead as to the actual operation of the starter .... guess AD decided he didn't want to be in the thread any more, not without precedent
Bill | | | | | Joined: Feb 2004 Posts: 29,775 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,775 | If you want to turn the engine over from under the hood, just use a big screwdriver between the linkage and the firewall to lever it down. That engages the starter pinion before the button gets pushed. Jerry
| | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | Yes to Hotrod Lincoln's suggestion. I've done that many times- that is the only way to do a compression check on those engines without having someone inside to push on the starter button.
Harvester | | |
