2 members (BC59, Uncles51), 103 guests, and 1 robot.
Topics128,041
Posts1,055,481
Members48,424
#425137 06/20/2008 9:34 PM
HI....on my 54 the PO installed a later chevy metal bed floor. We are in the process of cleaning and welding the mess that was made by the PO. We are going to use a product called Hercu-liner on the floor of the bed only. Has anyone used this product and if so do youy like it? Also, what is the best type of caulking/sealant to use in any cracks which will be covered by the Hercu-liner application.....Thanks and T/C Steve
The folks over at Herculiner recommend silicone caulking.
Call 1-877-HERCULINER (437-2854)
1949 "Heinz 57"
Dave O. #426362 06/24/2008 9:34 PM
I used Herculiner in a Jeep a few years ago and had it flake off in spots. I followed their instructions to the letter. It may work, but be warned that it may not. Herculiner is pretty thick and flexible, so I just taped up the back side of the seams and let it fill those in by itself, no caulk. It pretty much self levels.
Paint & Body Shop moderator
My buddies and I have used Herculiner on 4WD's in the past, it works real well for that. It is very durable and rough. It does scratch or rub off against rocks and stuff but that was pretty hard use.
It is very messy to put on but easy. Just tape everything off real well first and clean the surface prior to applying as per the insructions.
For the price and the do it at home ease, I think it is good stuff.
Blake51 #426417 06/25/2008 12:43 AM
Thanks to you all...T/C Steve
