| | | Forums66 Topics128,037 Posts1,055,469 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | HI....on my 54 the PO installed a later chevy metal bed floor. We are in the process of cleaning and welding the mess that was made by the PO. We are going to use a product called Hercu-liner on the floor of the bed only. Has anyone used this product and if so do youy like it? Also, what is the best type of caulking/sealant to use in any cracks which will be covered by the Hercu-liner application.....Thanks and T/C Steve | | | | | Joined: Jan 2007 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 79 | The folks over at Herculiner recommend silicone caulking.
Call 1-877-HERCULINER (437-2854)
1949 "Heinz 57"
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I used Herculiner in a Jeep a few years ago and had it flake off in spots. I followed their instructions to the letter. It may work, but be warned that it may not. Herculiner is pretty thick and flexible, so I just taped up the back side of the seams and let it fill those in by itself, no caulk. It pretty much self levels.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jun 2006 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 80 | My buddies and I have used Herculiner on 4WD's in the past, it works real well for that. It is very durable and rough. It does scratch or rub off against rocks and stuff but that was pretty hard use. It is very messy to put on but easy. Just tape everything off real well first and clean the surface prior to applying as per the insructions. For the price and the do it at home ease, I think it is good stuff. | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Thanks to you all...T/C Steve | | |
