Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 44 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#425512 06/22/2008 4:13 AM
Apprentice
Apprentice
hi,
any suggestions on how to replace the knobs on window handles?
thanks
what year? can you get the replacements? might be obvious from what they supply
Apprentice
Apprentice
the knobs i was referring to are on the window crank handle on a 46 chevy truck. apparently the knobs are pressed into the handle after they are heated?
Ex Hall Monitor
Ex Hall Monitor
I don't know if replacement are offered for a 46 but rarely were OEM knobs designed to be replaced. Aftermarket suppliers have designed replacement knobs that can be attached to the handles. I've not personally used them but I believe they are held in place with a large head screw. Even if you can't find specific 46 knobs you can probably find knobs that fit your handles.
I ordered knobs from Jim Carters, part # KB103, for my 4t6 although I haven't put them on. I believe you can drill out the old. I can look at the new ones tonight and let you know as I'm at work now. Good luck and have fun.
Dan
Apprentice
Apprentice
dan,
would be interesting to find out how you fared with drilling the old ones out.
thanks - nick
Nick,
I changed my approach. I cut the handle off with a hacksaw just under the knob. I then used a punch and with a couple of licks it popped out. The new one has a metal stud with ribs and just pushes in. Can take pictures if you need. Good luck and have fun
Dan
Moderated by  ndkid275, Phak1
