Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#4262 11/18/2004 6:58 AM
Junior Member
Junior Member
' Offline
The #HCA939219 is stamped on the block down by the distributer. I tried to find out what size motor this is but it wasn't listed in the casting numbers. Anybody know how to sipher this # ??
Also, on the rear end, stamped on top between the two ribs are the #'s "TL727" and "N657". Do these tell me what ratio the rear end is?? If so, what is it.
Any help is appreciated.
#4263 11/18/2004 7:18 PM
That first number looks like your serial number. For engine ID you need to look farther aft on the side of the block, sometimes behind the starter. There should be a raised number that is part of the casting. Probably under a lot of grease. Go to www.inliners.org to learn which engine it's from.
Fred
52 3600
69 C-10
