5 members (TooMany2count, Otto Skorzeny, MickeyP, Wally / Montana, Bill Hanlon), 101 guests, and 2 robots.
Topics128,052
Posts1,055,729
#426 06/26/2003 3:01 PM
Hey all! figured out part of fuel delivery problem. There was a "lacquer" of sorts in fuel tank from REALLY old gas which had solidified. It was clogging about 1/3 of the fuel pickup tube. Several hours of soaking, and "augering" w/ some electrical fence and...VOILA.
Already dark when that was completed, so rest of system will be another day.
By the way, it's a 1956 gmc 2-1/2 with 302.
The fuel pump is AC manufactured & has a secondary pump attached @ bottom. One end goes from or to the intake manifold, the other disappears(maybe into cab, have to check better). IS THIS A VACUUM PUMP? If not, what might it be and for what purpose? Thanks in advance for the help!
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
Yes, it's a vacuum pump. Should make your wipers work real good. cool
Fred
52 3600
69 C-10
Thank you!
Why does it also connect to intake? Does it help with the vacuum booster for the brakes?
