| | | Forums66 Topics128,074 Posts1,055,910 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 68 Member | | Member Joined: May 2003 Posts: 68 | Hey all! figured out part of fuel delivery problem. There was a "lacquer" of sorts in fuel tank from REALLY old gas which had solidified. It was clogging about 1/3 of the fuel pickup tube. Several hours of soaking, and "augering" w/ some electrical fence and...VOILA. Already dark when that was completed, so rest of system will be another day. By the way, it's a 1956 gmc 2-1/2 with 302. The fuel pump is AC manufactured & has a secondary pump attached @ bottom. One end goes from or to the intake manifold, the other disappears(maybe into cab, have to check better). IS THIS A VACUUM PUMP? If not, what might it be and for what purpose? Thanks in advance for the help!
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Yes, it's a vacuum pump. Should make your wipers work real good.
Fred 52 3600 69 C-10
| | | | | Joined: May 2003 Posts: 68 Member | | Member Joined: May 2003 Posts: 68 | Thank you! Why does it also connect to intake? Does it help with the vacuum booster for the brakes?
