1 members (Truckrolet), 156 guests, and 1 robot.
Topics128,115
Posts1,056,291
Members48,439
#425698 06/22/2008 10:21 PM
I am having trouble removing the drums to re-place the shoes and cant see the adjuster to loosen the brakes the remove the drum. Any suggestions?
1 Offline
I'm no expert but, I had to rent a large puller from a rental store to pull my drums. I've also heard you can heat the drum to loosen the rust. The puller worked great for me. good luck.
1954 Chevy 3100
1952 Chevy Suburban
You have to break the rust bond to get them to come off. Take a good hammer and smack the drum between and just outside of the stud circle. After a bit you will see rust dust spewing out from between the hub and the drum as you hit it. At some point you will probably be able to wiggle it and feel movement. Then rig up something to give some pulling tension and tap the drum on the edge outside perimeter. This is how I remove drums. If they turn then the shoes aren't holding them at this point. If you can pull the drum off a little and they hang up, the shoes could be catching a wear ridge.
1951 1 Ton Completed
It is usually the ridge on the drums, not rust that has to be overcome, and they have to be adjusted in to make them small enough to come off. A puller will work. Something will give unless you are planning on relining your old shoes because you might bend them.
jdl Offline
This is probably a simple thing that shouldn't have to be asked, but what do you have to do to get the drums off on the rear? Do they have a dust cap that covers the nut/cotter pin/bearing as the front or is it different? I don't really want to have to jack my truck up and take off the wheel just to find out it's something I don't understand, so I figured I'd ask.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
i cant seem to find the adjustment for the rear thats the main problem. It has two holes on top and an inspection plate on the forward side. The truck has been driven so I dont think its rusted on there so I am leaning torwards the puller.
jdl #425801 06/23/2008 4:20 AM
They are different than front if its a 1/2 ton. They come right off. The hub is actually part of the axle. That is what they call a semi floating axle. The wheel bearing is pressed on the axle and unless you have a rough bearing, leave all that alone. There are a few spring clips on the studs that screw off or pop off with a screw driver. Except if there is an excessive ridge from wear, you should be able to get the drum off by wiggling it off.
Leo Offline
Moderator
Moderator
I agree with truckernix that they are likely stuck on a wear ridge. A bit of patient wiggling with the occassional whack on the outer edge should do it.
