0 members (),
69
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | the clutch slave cylinder in my 61 C60 still works but leaks and i don't like to re-bleed it every time i want to move it so to move it is a chore... (lots of grinding and no clutch) i would think that a slave cylinder for a 1/2 ton pickup would be same since the engine and trans is the exact same that would be in a 1/2 ton (235 I_6 4spd top loader) but i'd figured i'd find out for sure. Is the slave cylinder for a 61 C60 the same as the slave for a 61 C10?
thanks Nate | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Is it a 235 powered truck? I remember a few years ago trying to find a rebuilt slave for an early 60's v8 c10. It was quite the chore. I think your best bet would to be get a rebuild kit and do it yourself. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy OldIronChevy, yes the clutch slave cylinder is the same for a 1/2ton and a C60 series 1960-62, Napa part number UP19097 $46.99, hope that helps. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | And be sure to buy a new slave cylinder. I drove trucks in the 60's with hydraulic clutches and it is way too much work installing a rebuilt and and risking having it fail. | | | | | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | whitedog: i kinda wished it was a V-8 but after your comment now i'm glad its the 235
3B: i live in a small town and only parts store we have is a NAPA and thats probly the one i'll go to so the napa part number really helps
crenwelge: i know what you mean i don't like to install rebuilt parts just cause i've heard stories of people doing jobs that take a long time and then the rebuilt part they got is junk
thanks for all the input Nate | | |
