| | | Forums66 Topics128,210 Posts1,057,465 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 31 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 31 | Don't know when in 1951 that my Chevrolet 1/2-ton Pickup was made. I know that there was a few changes in that year. Its a short bed 3100 series. Is there a way that you can tell or? I'm just curious about this. Any information on this would be very helpful. Thanks! ...diditanole
| | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | I got a 51 1/2 ton short bed and mine has 8 boards and yes there was a few changes in that year, BUT like Paul said "You can tell by the holes drilled in the cross braces. There will be a hole between each board" Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | 51 is a split year. Some had 8 boards and some had 9 boards. As the others said you can check your cross sills or rear cross sill to determine if it is an 8 board bed or 9 board bed. If you are completely replacing your wood bed (cross sills and all) then you can choose! It shouldn't matter either way. But if you use existing cross sills/rear cross sills, then you need to make sure which bed it is. | | | | | Joined: Feb 2007 Posts: 31 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 31 | | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | early months of 51 had 9 b4 mid year like april/may later had 8 look at your trucks ID plate for your date. my PO went cheap and bought 8 when i should have 9
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
