3 members (Hotrod Lincoln, Chip O, Steelonsteel), 125 guests, and 3 robots.
Topics128,196
Posts1,057,391
Members48,471
Don't know when in 1951 that my Chevrolet 1/2-ton Pickup was made. I know that there was a few changes in that year. Its a short bed 3100 series. Is there a way that you can tell or? I'm just curious about this. Any information on this would be very helpful. Thanks! ...diditanole
1 Offline
I got a 51 1/2 ton short bed and mine has 8 boards and yes there was a few changes in that year, BUT like Paul said "You can tell by the holes drilled in the cross braces. There will be a hole between each board"
Todd
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
51 is a split year. Some had 8 boards and some had 9 boards.
As the others said you can check your cross sills or rear cross sill to determine if it is an 8 board bed or 9 board bed.
If you are completely replacing your wood bed (cross sills and all) then you can choose! It shouldn't matter either way. But if you use existing cross sills/rear cross sills, then you need to make sure which bed it is.
early months of 51 had 9 b4 mid year like april/may
later had 8
look at your trucks ID plate for your date.
my PO went cheap and bought 8 when i should have 9 frown
Jim & Caroline
