| | | Forums66 Topics128,281 Posts1,058,473 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#42511 12/28/2003 2:01 AM | Joined: Apr 2002 Posts: 23 Member | | Member Joined: Apr 2002 Posts: 23 | I have a few questions about 292's for you guys. 1. About how many rpm's could a well build 292 handle? 2. Would it be possible to take it up to 5500 religiously? 3. Does the 292 have 6 ports for intake and 6 for exhaust? I'm asking this because I might eventually think about building a FI 292 with a single (or dual) turbo setup. Just for fun, of course Drew
55 2 dr 210- after college project 56 2 dr 210- after '55 project "D'oh"
#42512 12/28/2003 2:14 AM | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | 1.the 292 would handel 5500 rpm if had all proper hipower parts (such as forged piston high performnce conecting rod etc)
2. thay do not have 12 ports thay have 6
one for each two cylinders there is 12 port heads but thay are spendy and hard to find. whith twin turbos you would not need 12 ports
I wonce had the same idea about 250 six I picked the 250 becuse of the higher rpm and qicker revs I have herd of 250 taking 7000 rpm whith out exploding allthou I would be the last one to try it | | |
#42513 12/28/2003 6:28 AM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | oldchevy46 is correct, except for one thing...
The GM 292 factory head, along with the 230 and 250 inline 6s, is a 9 port head. There are three intake ports and six exhaust ports. Each intake port is shared between two cylinders. And from a performance standpoint if that weren't bad enough a head bolt boss is cast smack dab in the middle of each intake port.
There has been much research and testing done to improve the inlet flow of the stock cylinder head. Everything from an extreme port and polish and larger valves to removing the head bolt boss altogether and replacing it with lump of material which is either expoxied or bolted in to improve flow.
And with lightweight pistons you can safely take a well built, balanced 292 to 5500 rpms with ease.
-ftyler | | |
#42514 12/28/2003 5:13 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Cheapest way to improve the flow in the newer sixes is to make a cross flow head using a pair of sbc heads. Get a copy of Santucci's book on Chevy Inline Sixes, he covers all the aspects of rodding these engines.
Fred 52 3600 69 C-10
