| | | Forums66 Topics128,142 Posts1,056,782 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 72 | Hi Guys, I have my 49 GMC 1/2 ton ready to put the wiring back in and I was wondering which method would be the easiest or best. The 49 has a V8 and a steering column from my 77 GMC truck in it. I was going to use a wiring harness from my 77 GMC truck and mod it to fit my 49. Or would it be easier to use the stock 49 harness and adapt them to the 12 volt system? Or should I buy a harness from Painless?
Thanks.
kskt4 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you can get harnesses from a number of suppliers designed for your year with the necessary changes for modern columns and V8s with alternator, saves re-inventing if you can afford it
Bill | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I'll second red's comments. Buy a new 18 / 20 Cct. harness and save yourself a lot of grief. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I would not trust 30+ year old wiring. You will be removing it from the donor and working it into the 49. Lots can happen that you wouldn't want to happen.
~Jim
| | | | | Joined: Sep 2003 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 72 | Thanks Guys, Any dealers up in Canada where I could get a 18 or 20 circuit harness? I know of The Old Car Center in Langley.
kskt4 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the OCC can fix you up, 21 circuit set from American Autowire for any column you have and at a good price, give'em a call
Bill | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | You could try http://www.ezwiring.com/ they do pre wired fuse blocks with GM.connectors. They also mark everything every 5" so it's EZ! I paid $185 for peace of mind!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I started wiring mine today. I'm using a painless harness I bought years ago from someone on this sight for a killer price. I was a bit hesitant to begin but it looks quite simple. All the wires are marked the full length of each wire taking out the guess work. I would definately recommend this kit.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | Easiest isn't always the best. With that said, get a new harness from whichever vendor you want, (I've had a personal issue with American Autowire and can't recomend them)and when you're done have peace of mind as you ride and guide your new truck, smiling with the knowledge that this is one thing you won't be working on from the shoulder of the road with a flashlight in the rain. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Just ordered my harness from American Autowire. ... should be here this week sometime. The painless seemed to be easier to install but I decided on the American A. because I will be able to mount my fuse box anywhere I want or need to.
~Jim
