5 members (Jon G, Otto Skorzeny, Hanks custodian, dt235sd, 3800GUY), 166 guests, and 1 robot.
Topics128,105
Posts1,056,205
Members48,436
#423832 06/16/2008 9:08 PM
Does anybody know this value? I have pulled my tired cam and want to determine how much it has worn. From what I’ve found I need to multiply lobe lift by the rocker ratio to determine valve lift. Thanks for replies.
Curt B.
You Tube
Curt,
This is what 'Tony' had to say!
"The cam grinders say the rocker arm ratio on 235's and GMC's is 1.5.But it's 1.4 ,I've checked them out.So right out of the box,you're shy some lift and duration"
Thanks Tony.
Stuart
-Tom
1950 Chevy 3100 w/ 1956 235
Thanks guys. The .110” improvement in valve lift with my new 261 cam over the old one should perk it up a little. Although gutless I’m surprised it ran as good as it did considering lobe height varied as much as .030”
You Tube
