| | | Forums66 Topics128,034 Posts1,055,547 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 67 | ive got my truck trying to start now,i hot wired it. but the battery is dead now ive got it on the charger.
i am wondering what the difference is between a 3 termanial and 4 terminal ignition switch/lock cylinder. which one do you guys recomend i use?
i am going to try my best at cleaning the termanials on my original one, if i can get it out, but if thats a no go then ill go ahead and order one of the switch/lock cylinder you guys recomend from american classic parts.
thanks | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Hey, if you have voltage at the coil when you turn the key on(which you did say in another post right?) then your switch SHOULD be good. How about running a wire from the starter switch to the + side of the coil, and then see if the points spark. If not, then your problem lies somewhere in the wiring/grounding of the coil and distributor, not you switch.
P.S. I have had to run the wire from the starter switch to the coil, so it's not dangerous and won't hurt anything. | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | JDL, I have to commend you for your interest in Chevy trucks for a 13 year old you probably know more about them than the most of us do. Pleae keep the info coming on the "TRUCKS" But plaese don't become a "JOKER JR. in the "GREASSY JOKER SPOON"
| | | | | Joined: May 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 67 | jdl,
well i hot wired it and it worked, so i am figuring that its the connection with the switch, since they terminals were rusty and corroded. which would explain why it worked, and then just stopped working
i took the switch out and cleaned up where the wires connect with a dremel and wire brush end. they are lookin clean as a whistle. this should work becuase we tested the switch. tomorrow ill start her up, and take her around the yard. ( after bleeding the brakes, i got new brake lines installed!!! )
| | | | | Joined: May 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 67 | i got the switch working. so its started but i cant move it becuase one of the parking brakes is stuck on!! the push rod wont pull it out, so im gonna work on freeing that one side up and it SHOULD be able to be backed out..lol | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | Good luck on the maiden voyage bmx!  | | |
