5 members (55shaker, TUTS 59, 2-Ton, jmoore, dunfire), 108 guests, and 1 robot.
Topics128,048
Posts1,055,541
Members48,425
#423297 06/15/2008 12:13 AM
ive got my truck trying to start now,i hot wired it. but the battery is dead now ive got it on the charger.
i am wondering what the difference is between a 3 termanial and 4 terminal ignition switch/lock cylinder. which one do you guys recomend i use?
i am going to try my best at cleaning the termanials on my original one, if i can get it out, but if thats a no go then ill go ahead and order one of the switch/lock cylinder you guys recomend from american classic parts.
thanks
jdl Offline
Hey, if you have voltage at the coil when you turn the key on(which you did say in another post right?) then your switch SHOULD be good. How about running a wire from the starter switch to the + side of the coil, and then see if the points spark. If not, then your problem lies somewhere in the wiring/grounding of the coil and distributor, not you switch.
P.S. I have had to run the wire from the starter switch to the coil, so it's not dangerous and won't hurt anything.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
jdl #423331 06/15/2008 2:43 AM
JDL, I have to commend you for your interest in Chevy trucks for a 13 year old you probably know more about them than the most of us do. Pleae keep the info coming on the "TRUCKS" But plaese don't become a "JOKER JR. in the "GREASSY JOKER SPOON"
jdl,
well i hot wired it and it worked, so i am figuring that its the connection with the switch, since they terminals were rusty and corroded. which would explain why it worked, and then just stopped working
i took the switch out and cleaned up where the wires connect with a dremel and wire brush end. they are lookin clean as a whistle. this should work becuase we tested the switch. tomorrow ill start her up, and take her around the yard. ( after bleeding the brakes, i got new brake lines installed!!! )
i got the switch working. so its started but i cant move it becuase one of the parking brakes is stuck on!! the push rod wont pull it out, so im gonna work on freeing that one side up and it SHOULD be able to be backed out..lol
Good luck on the maiden voyage bmx! thumbs_up thumbs_up
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
