6 members (Otto Skorzeny, ShopRag, Gdads51, 55shaker, 78buckshot, Woogeroo), 147 guests, and 3 robots.
Topics128,268
Posts1,058,382
Members48,485
#423181 06/14/2008 4:26 PM
Can anyone tell me if the old fuse blocks for the mid-to late 50's trucks had a constant hot side and an accessory side that came on only when the ignition key was turned to accessory or start? This would be the fuse block/panel that held about 6-8 glass fuses for things such as heater, radio, etc.
Rick #423190 06/14/2008 4:45 PM
Rick,
I have enclosed a link to a wiring diagram of the truck with a five fuse box. The power to the box is not switched with a ACC function on the ignition switch....I don't even know if it had a ACC position.
The fuses are for HI, LOW (hdlts),PARK, STOP and TAIL. I think these circuits were always powered, or in the case of the headlights, powered when the headlight switch was pulled ON.
http://chevy.oldcarmanualproject.com/electrical/wiring/images/49ctsm1202.jpg
Stuart
atomarc #423226 06/14/2008 6:15 PM
Mid-to-late 50s?
Rick,
Stuart is correct for the 5-fuse box used through 1949 and the 2-fuse box used for the rest of the Advance-Design years. Most likely the same holds true for 55-60 (mid to late 50s?) trucks.
Here is a 1955-2nd series wiring diagram:
http://chevy.oldcarmanualproject.com/shop/1955truck2/55ctsm1202.htm
The 55-2nd Shop Manual states that there was also an accessory junction block inside the dash panel.
What year truck are you referring to?
Tim
