| | | Forums66 Topics128,268 Posts1,058,378 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | Can anyone tell me if the old fuse blocks for the mid-to late 50's trucks had a constant hot side and an accessory side that came on only when the ignition key was turned to accessory or start? This would be the fuse block/panel that held about 6-8 glass fuses for things such as heater, radio, etc. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Rick, I have enclosed a link to a wiring diagram of the truck with a five fuse box. The power to the box is not switched with a ACC function on the ignition switch....I don't even know if it had a ACC position. The fuses are for HI, LOW (hdlts),PARK, STOP and TAIL. I think these circuits were always powered, or in the case of the headlights, powered when the headlight switch was pulled ON. http://chevy.oldcarmanualproject.com/electrical/wiring/images/49ctsm1202.jpgStuart | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Mid-to-late 50s? Rick, Stuart is correct for the 5-fuse box used through 1949 and the 2-fuse box used for the rest of the Advance-Design years. Most likely the same holds true for 55-60 (mid to late 50s?) trucks. Here is a 1955-2nd series wiring diagram: http://chevy.oldcarmanualproject.com/shop/1955truck2/55ctsm1202.htmThe 55-2nd Shop Manual states that there was also an accessory junction block inside the dash panel. What year truck are you referring to? Tim | | |
