3 members (Jon G, Hanks custodian, Bill Hanlon), 143 guests, and 10 robots.
Topics128,078
Posts1,056,027
Members48,433
Late type, say '58-62? I just have mine looped around the bell crank and up to a manifold bolt but I suspect that's wrong.
Paint & Body Shop moderator
Which carb are you using?
Is there a little tab with a hole in it on the linkage rod?
Rochester B. I had to make a new linkage rod. I remember the tab on my old 216. I need to know where the other end of the spring goes.
I think there is a bracket that bolts on with a oil pan bolt to hook the spring to
