1 members (Bill Hanlon),
137
9
Mod | | | Forums66 Topics128,078 Posts1,056,027 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#42311 06/20/2003 10:28 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Late type, say '58-62? I just have mine looped around the bell crank and up to a manifold bolt but I suspect that's wrong.
#42312 06/21/2003 4:43 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Which carb are you using? Is there a little tab with a hole in it on the linkage rod?
#42313 06/23/2003 2:46 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Rochester B. I had to make a new linkage rod. I remember the tab on my old 216. I need to know where the other end of the spring goes.
#42314 06/23/2003 4:09 AM | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | I think there is a bracket that bolts on with a oil pan bolt to hook the spring to | | |
