1 members (Southerntruck), 162 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
#422634 06/13/2008 2:58 AM
Apprentice
Apprentice
Well,I need some suggestions!Been driving my '49 with a 235 on short trips after a complete restoration.I restored it back to original condition with the 6 volt system. You couldn't ask for it to crank any better when it is cool but after it gets hot it turns over very slowly. After it cools off some it cranks perfectly.New 750amp battery,generator shows charging,new cables,timing is right on the mark.Engine was completely rebuilt and runs good as was the starter. I need to get this little problem fixed but where to begin? Thanks,Chip
jdl Offline
The starter may be the cause. When I try to start my truck(1954 with the original 235) the starter cranks fast but after a few seconds the starter gets hot and slows down.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
Are you using the after market braided ground cables? I had the same problem from these cables, (they are not heavy enough) I changed to #2 cables and everything is fine. To see if this is your problem, get it hot and run a jumper cable straight from the battery to the engine.
Apprentice
Apprentice
AD,Thanks for the tip on the battery cables.Went today and bought a #2 36"long ground cable and went straight from the battery to the engine and left the braided cable from the engine to the frame.Drove the truck for about an hour until it was good and hot,parked on the top of a hill and shut it off.It cranked perfectly every time.Thanks a lot. Chip
Chip, I am gald it is working as you like. I didn't run a cable from the battery to the engine, I changed the cables from the battery to frame and frame to engine to #2. I did run a jumper cable from battery to engine after engine was hot and this told me what the problem was.
