4 members (HandyAndy, Jon G, 2 invisible),
148
Mod | | | Forums66 Topics128,087 Posts1,055,982 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 31 Apprentice | | Apprentice Joined: Oct 2006 Posts: 31 | Well,I need some suggestions!Been driving my '49 with a 235 on short trips after a complete restoration.I restored it back to original condition with the 6 volt system. You couldn't ask for it to crank any better when it is cool but after it gets hot it turns over very slowly. After it cools off some it cranks perfectly.New 750amp battery,generator shows charging,new cables,timing is right on the mark.Engine was completely rebuilt and runs good as was the starter. I need to get this little problem fixed but where to begin? Thanks,Chip | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | The starter may be the cause. When I try to start my truck(1954 with the original 235) the starter cranks fast but after a few seconds the starter gets hot and slows down. | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | Are you using the after market braided ground cables? I had the same problem from these cables, (they are not heavy enough) I changed to #2 cables and everything is fine. To see if this is your problem, get it hot and run a jumper cable straight from the battery to the engine. | | | | | Joined: Oct 2006 Posts: 31 Apprentice | | Apprentice Joined: Oct 2006 Posts: 31 | AD,Thanks for the tip on the battery cables.Went today and bought a #2 36"long ground cable and went straight from the battery to the engine and left the braided cable from the engine to the frame.Drove the truck for about an hour until it was good and hot,parked on the top of a hill and shut it off.It cranked perfectly every time.Thanks a lot. Chip | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | Chip, I am gald it is working as you like. I didn't run a cable from the battery to the engine, I changed the cables from the battery to frame and frame to engine to #2. I did run a jumper cable from battery to engine after engine was hot and this told me what the problem was. | | |
