2 members (51sub, Possum), 113 guests, and 4 robots.
Topics128,265
Posts1,058,364
Members48,485
#42205 03/29/2002 1:53 AM
Anonymous
Unregistered
Anonymous
Unregistered
I am going to be doing some work on my landlords truck this summer. He knows little about cars, and helped a friend restore His 65 Chevy C10 truck. I know my way around cars and am going to upgrade his single M/C to a dual, possibly power M/C Drum,Drum. Is there a bolt on upgrade? I work in a parts store, so I can get parts for little money. What else will I need? will I need a proportioning valve as well?
Is there a direct bolt in M/C? or will I need to get an adapter?
Thanks Guys
#42206 03/30/2002 4:52 AM
Anonymous
Unregistered
Anonymous
Unregistered
Since I worked this evening, I did a little investigating. The M/C from any 67-72? truck is a bolt in replacement... Im still not sure if I will need a proportioning valve though, It will be Non power, drum/drum brakes.
#42207 03/30/2002 6:25 PM
I am not a brake expert, but I understand you don't need proportioning valve if using drum/drum. You can check some of the sites like customclassic.com, mpbrakes.com, in their tech sections and they have some brake plumbing diagrams for different applications.
