| | | Forums66 Topics128,089 Posts1,056,437 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Hi Guys Just finished cleaning the carb and tried tuning the engine. I used a vacuum gauge to set the idle. The maximum vacuum I was able to achieve was 15.5 in. Hg. The book says I should get between 17-21. Should this low number be expected at Calgary's elevation of 3500' above sea level, or do I need to do more work?
Thanks for the help.
Peter
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Expect less vacuum at higher elevations. A lot of vacuum gauges are not all that accurate. If you're worried about a vacuum leak, spray some Diesel or Marvel mystery Oil around the carb and intake manifold gaskets. If you have a vacuum leak, it will suck it in and the exhaust will smoke white. | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Thanks CR.
That's what I thought, but wanted confirmation.
Peter
| | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | A rule of thumb for manifold vacuum is a loss of 1" Hg per thousand feet above sea level. With that, you could expect 3.5" Hg less than the 17-21 level given. Even with the expected loss from altitude, your level of 15.5" Hg seems low. Make sure your initial timing is set correctly, and the idle speed is 550-600 RPM after setting the timing. The idea that your gauge is off is equally valid, but there isn't a good way to check that without a second gauge or a calibration set-up.
Harvester | | |
