3 members (Otto Skorzeny, Jay R, Gray_Ghost), 157 guests, and 2 robots.
Topics128,088
Posts1,056,416
Members48,443
#421404 06/09/2008 4:17 AM
Hi Guys
Just finished cleaning the carb and tried tuning the engine. I used a vacuum gauge to set the idle. The maximum vacuum I was able to achieve was 15.5 in. Hg. The book says I should get between 17-21. Should this low number be expected at Calgary's elevation of 3500' above sea level, or do I need to do more work?
Thanks for the help.
Peter
Expect less vacuum at higher elevations. A lot of vacuum gauges are not all that accurate. If you're worried about a vacuum leak, spray some Diesel or Marvel mystery Oil around the carb and intake manifold gaskets. If you have a vacuum leak, it will suck it in and the exhaust will smoke white.
Thanks CR.
That's what I thought, but wanted confirmation.
Peter
A rule of thumb for manifold vacuum is a loss of 1" Hg per thousand feet above sea level. With that, you could expect 3.5" Hg less than the 17-21 level given. Even with the expected loss from altitude, your level of 15.5" Hg seems low. Make sure your initial timing is set correctly, and the idle speed is 550-600 RPM after setting the timing. The idea that your gauge is off is equally valid, but there isn't a good way to check that without a second gauge or a calibration set-up.
Harvester
