Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (cmayna, baldeagle), 51 guests, and 2 robots.
Topics128,006
Posts1,055,268
Members48,418
#42095 05/16/2005 5:57 PM
My engine is out being machined. New pistons, bearings etc. My machinist would like to ballance the crank but says its not absolutly necissary. What do you guys think. He says it will help eliminate any vibration.
#42096 05/16/2005 6:17 PM
1 Offline
definately. it will make the engine run smoother, and last longer due to less vibrations. i would balance the entire bottom end (crank, rods, & pistons) but that it just me. definately do the crank.
what size motor is it?
2003 ford lightning
1959 chevy 36
#42097 05/16/2005 7:44 PM
My engine guy also balanced the pistons and flywheel for an extra $125. He used several drill sizes on the flywheel, finally making dimples with a 1/8 in. diam drill. That impressed me. I think it was well worth the money.
#42098 05/20/2005 12:42 AM
The engine is a GMC 228. It was pretty tired as the cylanders were worn +/- 42thou. But still a strong heavy block with plenty of meat left. Will bore 60 over. Crank has alreadey been turnd 10 thou. But its the origional engine and thats my plan for the whole truck. Yes i have decided to ballance the crank rods pistons flywheel and ballancer.
The frame is painted, front end completed and Im really feeling good about the whole truck. Not much more grease and filth left and I dont call her "Rusty" anymore. Need a new name. Anyway thanks for the input on ballancing. G. Lee
#42099 05/20/2005 12:47 AM
They didn't come finely balanced from the factory and so most people have no idea how smooth they could run. Things must have impoved because by the time they got to the 230/250 series, there was a world of difference!
1951 1 Ton Completed
