3 members (TUTS 59, 1955 1 Series, dt235sd), 97 guests, and 2 robots.
Topics128,141
Posts1,056,488
Members48,441
#42067 05/24/2004 12:40 AM
Are the new replacement ring and pinion sets any quieter than the originals or do they have the same old howl? I'm thinking of rebuilding my original with a taller gear and disk brakes but I would like it to be as quiet as a modern diff. any experiances shared would be appreciated.
Larry
P.S. I have a 56 Sub,283, and am building it to get a lot of miles in its future.
When I replaced the entire rear under my '55 sub it got a lot quieter. Of course, the front seal was gone, and so were the pinion bearings...
Going from to 3.08 gears lowered the engine noise too.
yeah Larry - the noise is age - needs new bearings and the gears are prolly worn - my noisey 57 rear gears were chipped and just replacing the gears w/ used of same year helped, new pinion bearing did the rest
Old Sub,
What year/model rear end did you use to get the 3.08 gears? Is it a 5 or six lug rear? My donor 55 GMC rearend sat too long in the WA humidity, and looks like I'll only be able to save the center section as I will have to use a cutting torch to get the drums off. Hopefully can save the backing plates and brake parts. Most likely will weld the perches on the 48 rear, and swap the third-member and have a driveline built. Tired of replacing the front u-joint at $50 a pop. ANd I like driving it too much to leave it be. It currently is my daily driver, since fixing the accelerator pump in the carb, and since the Datsun is down for a brake rebuild.... But the 48 gets better mileage than the 94 454 Sub.... Gotta get the Datsun back on the road as these gas prices are out of control....
Garry
Garry K in Pac Nor West
1948 Chevy PU 235 SM420 4 spd
1932 **** B pu
1964 Datsun 4x4 with SBC, SM465 4spd and Rockwell xfer Dana 44Fr and 12 Bolt Rr.
Garry - - -
Before you fire up the torch, try this:
Get a can of Kroil from Kano Laboratories in Nashville, Tennessee, and soak the drum/axle area with it. This stuff is fantastic at breaking loose rust! I've used it to free up engines that sat out in the weather for years.
www.kanolabs.com
I put 3.38 gears in my 55.1 and now it is VERY quite compared to the Original, worn out, whinny gears. Also brought the RPMs down to make engine noise a little less. Then I put on new tires to quite the road noise.
Buddy in AK
"Keep the shiny side up....."
'50 GMC Suburban
'55 1st Chevy Pickup
http://community.webshots.com/user/buddyinak
Quote
Originally posted by Garry K:
Old Sub,
'73 Chevelle wagon with 5 lugs. I bought the entire car for just $10. Had to cut the coil spring mounts off and weld on spring pads.
I'm so pleased with it that I've located another Chevelle wagon which I plan to get the rear from.
I have a '55 1st pickup that I'm told has a '58 rear under it. I've not idea what ratio it might be, but apparently it fit easy enough.
Thanks for the replys gentlemen, but I am now undecided. Hmmmm, modern or restore the old? Once you make up your mind the rest is easy.
Larry
