| | | Forums66 Topics128,052 Posts1,055,774 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 77 | I have a 53 5700 COE. It wasn't completely assembled when I got it and I have a few questions for you bunch of wizards. I found the top of the radiator has been spaced forward 2 inches and the bottom is still in the original location. Fan has a spacer on it. It has a 58 235 in it. My understanding is it came with a 235, so I don't know why the rad is spaced at the top unless there are different water pumps for these engines. Because of the spacing, the inner fenders won't line up without alot of forcing them into position. I don't know if the inner fender lip goes inside the front fender lip sandwiched beteween the grill and outer fender,or outside the lip. Any help or pictures would be greatly appreciated. Thanks, John | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Can you remove the spacer on the fan and put things back where they belong. I don't have a COE, but my 49 has the fender sandwiched between the grill and the inner fender. Cleon | | | | | Joined: Jan 2008 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 77 | I thought about that, but the fan would hit the rad. If I take the spacer out between the fan and pump pulley,the fan will hit just about everything on the front of the engine. I appreciate the info on your sheetmetal. Yours will be the same as mine as far as assembly goes I think. Maybe Spanky will see this post and chime in for me also. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The '58 235 is longer than the '53 235 in the water pump area. The '53-'54 235's have the water pump partially mounted to the head and it is up high. The later blocks have the water pump completely in the block and it mounts lower. Somebody moved the radiator to accomodate this. In the conventional cab trucks, people either shorten the water pump shaft and live with a fan that sits too low on the radiator, or get one of the water pump adaptor plates after market that let you use a 216 or early 235 water pump with a later block. I recommend doing this and putting the radiator back to the original location.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jan 2008 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 77 | I knew there was a wizard lurking on this space !! Got any idea where I can get one of the adaptor plates? Again, thank you very much for the info. | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | The adapter plate can be purchased from Jim Carter Cleon | | |
