0 members (),
61
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#42007 01/07/2003 2:07 AM | Joined: Jan 2003 Posts: 6 Member | | Member Joined: Jan 2003 Posts: 6 | i'm new here folks but i need some help. my boss has a 65' C-60 line truck out behind the shop with a v-8 sitting in it. i can't figure out what size it may be. i found only one tag on the inside cowl of the truck. info as follows: 19500 gvw,trans (looks like) c4, rear axle- c15642, ratio- 8-72, trim -std, paint-30101. now these two numbers are: 157 and 84. all of this inf is stamped on a metal plate with 5 different motor and HP listings. my dad said its probably a 292ci, but isn't that a six cylinder? its definitley not a 409 (BB). according to the tag i found , that leaves it to be a 327 (i hope it is) or one of two 348's. i was told that the later was also a big block. can ya'll help me out? by the way, this is an old line truck that is complete far as i can tell and that it ran when it was parked during the mid 80's. thanks in advance. roy | | |
#42008 01/07/2003 3:31 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | 409 and 348 look basically the same the valve covers look like an inverted 'W'. Since you seem to feel that it is not a 409, then probably isn't 348 either. That leaves 283 or 327 unless someone swapped the motor. There should be an engine ID on the front of the motor under the passenger side head. See if you can find, might have to clean a bit.
Regards, Larry
I don't own a vehicle that isn't old enough to drink. | | |
#42009 01/07/2003 5:09 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Go to www.mortec.com It has small block casting numbers and tells you where to find them. The 292 is a six. Probably a 327 unless someone did a transplant.
Fred 52 3600 69 C-10
#42010 01/07/2003 5:32 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | How wide are the valve-covers? about 4`` or 6``?
#42011 01/07/2003 10:09 PM | Joined: Jan 2003 Posts: 6 Member | | Member Joined: Jan 2003 Posts: 6 | ok, here is what i found out today. this number is stamped on the ledge on the passenger front next to the timing cover: F0208YA. according to the website that i looked up it was assembled in Flint,MI on Feb. 8th. i haven't figured out the "YA" part yet. secondly, i found the VIN# over the door. it is as follows: C6335A116929. now i'm trying to figure out what that tells me. roy | | |
#42012 01/07/2003 10:11 PM | Joined: Jan 2003 Posts: 6 Member | | Member Joined: Jan 2003 Posts: 6 | oh, the valve covers are closer to 4" wide with "chevrolet" stamped old style into them. there are no openening for oil filler or pcv valve if that helps. the oil filler is in front of the thermostat housing. roy | | |
#42013 01/07/2003 10:44 PM | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | hello royleeair. if you can, jump up and look straight down between the fire wall and the engine. on the drivers side and on top of the bell housing flange there will be a number cast into the iron[seven or eight numbers]. you will probably have to clean this area to see the number.it is a block casting number and will further identify the engine. then either tell us the number on this forum and those of us that have a list handy can tell you what it is, or you can look it up yourself as was mentioned earlier on the mortec list. good luck.
our garage is a non-profit organization
#42014 01/07/2003 11:10 PM | Joined: Nov 2001 Posts: 58 Member | | Member Joined: Nov 2001 Posts: 58 | I make it as a 327 ci. 240 hp 4 barrel engine in a C20 and C25 truck. Built at the Flint plant February 8th. Sound right? | | |
#42015 01/07/2003 11:21 PM | Joined: Nov 2001 Posts: 58 Member | | Member Joined: Nov 2001 Posts: 58 | Just looked again and the YA code can signify a 1966 or 1969 366 big block from a L-41 50 truck. The 66 is 222 hp and the 69 is 235 hp. Here is a link to read the codes at the end of the stamped number. So you really need the casting number I think to be sure. http://www.nastyz28.com/spmenu.html | | |
#42016 01/08/2003 1:43 AM | Joined: Jan 2003 Posts: 6 Member | | Member Joined: Jan 2003 Posts: 6 | 38spshl, its definitly a small block but it is sitting in a 1965 C-60 Line Truck. i will climb up into the engine bay tomorrow and see if i can see the casting number. i'm wanting it to rebuild it before the boss sends it to the graveyard. i'll get the numbers on here tomorrow. thanks ya'll. roy | | |
#42017 01/08/2003 4:34 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | On Nasty's site under small blocks there is a YA for a 68, 327. My engine ID says it is a 69 or earlier V8. darn engine IDs, VIN numbers are a pain you can go to 2 sites and get a 1/2 dz different answerts. I thought my casting number CD was so great, not.
Larry
#42018 01/08/2003 10:40 PM | Joined: Jan 2003 Posts: 6 Member | | Member Joined: Jan 2003 Posts: 6 | ok folks, got a bit of news today from the boss's dad (he actually purchased the truck in 78'). he was told the motor had been swapped. i got email back from MORTEC and they say its a 65' 327ci/185hp w/2bbl. basically original. i did some crawling during lunch and got this engine casting #3782870. ( first digit may be an 8, not sure) and this number came of the passenger side head under the valve cover, #3884520 and in the center of the head is GM 23. i'm gonna keep lookingto see what i have here. i could use all of your inputs and thanks again. roy | | |
#42019 01/08/2003 11:52 PM | Joined: Jan 2003 Posts: 6 Member | | Member Joined: Jan 2003 Posts: 6 | ok folks, i'm pretty sure its a 327ci. from the numbers i got today from the block and the one head it is a 62-67 327ci w/ 60cc heads. original, don't know but it could be. i feel confident that it is and it should make a nice addition to my wifes little S-10. i'll keep checking here for your posts and thanks again for the help. roy | | |
