2 members (Gdads51, Guitplayer), 76 guests, and 3 robots.
Topics128,162
Posts1,056,950
Members48,458
I wanted to change the gear oil in the rearend of my truck today, but I cant seem to get it out. Someone said that taking out one of the bolts for the cover should let the oil out, but nothing came out. Do I have to take the cover off to get the oil out? The rear axle in my truck is a Dana 44. frown
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht-
Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
The Dana 44 I had in my Willys (and the Dana 25, for that matter) had a plug in the cover for filling and a plug in the casting for draining. The drain accepted a 1/2" socket wrench extension. It got easily covered over with muck, though, so it was easy to miss. If you don't have one of those, you may have to take the cover all the way off if the seal is good.
Paint & Body Shop moderator
Thanks for the quick reply. I found the plug at the bottom. It was covered by dirt and grease. I got it out, and the oil was as dark as night. It probably hasnt been changed since the reagan administration :rolleyes:
Jonathan S. Keffer
Quote
According to the records on my 52, when I bought her 4 years ago the gear lube was last changed during the Johnson administration. :p
Fred
52 3600
69 C-10
For those Rear ends and tranny's that don't have a drain plug, you can use a siphon to get the old oil out thru the filler hole
[img]http://www.laroke.com/larryk4674/2001/bb032001ct.jpg[/img]
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
