4 members (TUTS 59, Lostbuthaulinass, 32Fordpuchoptop, moparguy), 106 guests, and 3 robots.
Topics128,141
Posts1,056,485
Members48,441
I have installed the speed bleeders at all four corners and was just thinking if I'm able to just open all the bleeders up and bleed all of them at the same time or do I just need to do each one individually. I've somewhat bled brakes before but didn't know if I could get away with doing all of them at the same time or not since these have the check valve built in. Thanks for the help!
Jeremy
Any air bubble means spongy brakes. I would do one wheel at a time.
Do them one wheel at a time, then you will be sure all air and old fluid is removed completely between the Master cylinder and that wheel cylinder. Otherwise unequal lengths in the lines, potentialy unequal pressures, you may leave some old fluid or air in your lines, probably the farthest back one. Finally, you can better keep up with the fluid level in your master cylinder making sure it does not run dry and pump more air into your lines goind with one at a time.
R-Bo
1966 GMC 305V6 in the family
yes, one at a time..start on the passengers rear, then drivers then move up front....repeat....a few times
1952 Chevy Shortbed
Photos in Photobucket
Does RR, LR, RF, LF bleeding hold true on every vehicle? On my '50 the longest line from the master is the driver's rear because the line to the rear runs down the passenger side. While the right rear cylinder is physically farther away, it is actually on a shorter line than the left/driver's rear. Same is true upfront with the stock lines because the LF line comes from the passenger side again. Wouldn't you bleed it LR, RR, LF, RF?
Steve O
1950 Chevy 3100
261, 4 speed
Purchased 1977
1964 Pontiac Lemans Convert
jdl Offline
Check your owners/shop manual, I have no idea, of course if someone decides to run a brake line on the drivers side to the rear wheels, it wouldn't be the same.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
Yes, the sequence of bleeding is different for different vehicles. The rule-of-thumb is furthest away from the master cylinder is first, progressing to the next furthest, etc, to the closest to the master cylinder.
On big trucks with a hydrovac unit, the sequence is described in the Chevrolet Truck Shop Manual (or GMC Maintenance manual).
Thanks for the help guys!!
