2 members (klhansen, TUTS 59),
64
Mod | | | Forums66 Topics128,066 Posts1,055,873 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#41952 01/22/2002 9:37 AM | Joined: Sep 2001 Posts: 13 Member | | Member Joined: Sep 2001 Posts: 13 | Hey there. a coupole of questions to any one. I have a 1950 sedan. 216, rochester one barrel roughly 92 ponies on a good day. Whay would be my power increase on a late 60's 292 with a triple carb setup and a mild Isky cam?????.....thanks. also i'm sure I will have to get a different bell housing, Yes????
justin kohut 1950 fleetline/kustom 1950 Buick super (straight eight)
#41953 01/22/2002 4:27 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The 292 setup as you described plus a set of headers will be in the 200 hp. range.
Fred 52 3600 69 C-10
#41954 01/22/2002 4:38 PM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Not a bolt-in swap. Many changes to side mounts, modern bellhouse, tranny tail mount, maybe radiator moved ahead, not worth it. Later 235's will fit with waterpump change, can get speed parts from Cliffords for them. Check back in forum's, there is a string of articles on this swap if you do search. About the same stuff you would have to do for a V-8 swap, might as well do that for all the trouble.  Keep the six, buy a different car for a "Hot Rod"! :p
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#41955 01/22/2002 4:40 PM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Forgot, car trans is diff than truck and won't fit modern bellhousings, then if you change that, may need open drive shaft and rearend, list goes on and on. :rolleyes:
