3 members (Phak1, NorCal52Suburban, Wayne67vert), 86 guests, and 1 robot.
Topics128,049
Posts1,055,546
Members48,425
#41952 01/22/2002 9:37 AM
Hey there. a coupole of questions to any one. I have a 1950 sedan. 216, rochester one barrel roughly 92 ponies on a good day. Whay would be my power increase on a late 60's 292 with a triple carb setup and a mild Isky cam?????.....thanks. also i'm sure I will have to get a different bell housing, Yes????
justin kohut
1950 fleetline/kustom
1950 Buick super (straight eight)
#41953 01/22/2002 4:27 PM
The 292 setup as you described plus a set of headers will be in the 200 hp. range.
Fred
52 3600
69 C-10
#41954 01/22/2002 4:38 PM
Not a bolt-in swap. Many changes to side mounts, modern bellhouse, tranny tail mount, maybe radiator moved ahead, not worth it. Later 235's will fit with waterpump change, can get speed parts from Cliffords for them. Check back in forum's, there is a string of articles on this swap if you do search. About the same stuff you would have to do for a V-8 swap, might as well do that for all the trouble. frown Keep the six, buy a different car for a "Hot Rod"! :p
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#41955 01/22/2002 4:40 PM
Forgot, car trans is diff than truck and won't fit modern bellhousings, then if you change that, may need open drive shaft and rearend, list goes on and on. :rolleyes:
G.L. Grumpy's
Old Iron Ranch
